Variable Resistors (alps)
I have guitar effect pedal Boss Dual Overdrive.
I took them out:
I tried to search them in UA, and found nothing. Service center wants almost as much as new pedal cost.
Specs are:
dual row (indapendable) resistors 100 K, 230 K, 10 K
dual row (but one knob) switch - 3 positions 5x2 pins
I took them out:
Specs are:
they are called "pots" over here. short for potentiometers. do some checking for those im sure you can find what you need. this is a good place...
www.allelectronics.com
Thanx, but I didn't find there.
I found out that those pots are Alps 9mm with metal shaft:
Alps 9mm
what's the difference between dual unit for volume and dual unit for tone? What pots do I need?
Alps 9mm
