I thought coilovers can only lower the car but lowering can be adjusted like 2-7 cm.
depends on the coilover. mine didnt get that high when i messed with them, but definately higher than stock.
duh... why didn't I put coilovers on....
I didn't want to lower my car, cause roads here is POS, so I left my springs stock... |
there aren't coilovers. keep guessing. i'm stuck at work till 4, ugh. lets just say, the car won't drive very far as is.
you put something under the springs?
nope. stock springs, KYB struts. keep trying.
looks like you're just jacking it up, you got the ghetoo chock under the wheel (the wrong wheel :lmao).
those are 16"s with the same outer diameter tire. ok, i'll be straight with you guys.
the car's ride height does change a little when you take the engine out. BTW, I'll be parting stuff out from this red tib later this week. wink1.gif http://img138.imagevenue.com/loc138/...20_06_2003.jpg |
