<span style="color:#0040ff">Anyone with a service manual for a 99 Tiburon?</span>
My car has roughly 46k miles on it now and since it's being driven sparingly for the next 8 months, (stored in GFs garage), I want to put it in for service when I get back from deployment. So what other services does the OWNERS MANUAL call for up to and beyond 50k miles? The tranny has already been taken care of, new brakes and rotors will be installed. |
Hootie, I have a 99 tib. The 50K mile marker has the following requirements for maintance. (52,500 actually, according the manual)
Inspect, clean, adjust, or replace as necessary the following: Auto trans fluid and filter The 60,000 mark is the big one Inspect, cleam, adjust, or replace the following: Fan belt Manual Transaxle oil (opps, need to do this myself) Autotrans fluid and filter Brake fluidBrake hoses and Lines Rear drake drums/lining, parking brake Brake pads, calipers, and rotors Exhaust pipe and muffler Suspension mounting bolts Steering gear box, linkage, boots, lower arm ball joint Power steering pump, belt, and hoses Drifeshaft and boots Air conditioning refiridgerant Replace the following: Engine coolant Timing belt.. (in California this maintance is recommended, but not required?) Hope that helps man.. the 50,000 mark is easy.. the 60,000 EVERYTHING gets looked at. |
split
Well, I will prolly just have all of that stuff done early. I'm putting new rotors and brake pads on it when I get back and just have them once the whole car over too see if anything needs anything BEFORE the warranty runs out. :drunk:
I also have the factory shop manual for the 99 (gotta love eBay) so if you need any instructions, I can post them up for you.
