2.2 miles
Canadian sniper sets world record with 2.2-mile pickoff of ISIS fighter A Canadian sniper set what appears to be a record, picking off an ISIS fighter from some 2.2 miles away, and disrupting a potentially deadly operation by the terror group in Iraq. Shooting experts say the fatal shot at a world-record distance of 11,316 feet underscores how stunningly sophisticated military snipers are becoming. The feat, pulled off by a special forces sniper from Canada’s Joint Task Force 2, smashed the previous distance record for successful sniper shots by some 3,280 feet, a record set by a British sniper. "The Canadian Special Operations Command can confirm that a member of the Joint Task Force 2 successfully hit a target from 3,540 metres [2.2 miles]," the Canadian military said in a statement. While officials would not say where the shot took place, the statement noted the command "provides its expertise to Iraqi security forces to detect, identify and defeat Daesh activities from well behind the Iraqi security force front line in Mosul." The new record was set using a McMillan TAC-50, a .50-caliber weapon and the largest shoulder-fired firearm in existence. Ryan Cleckner, a former U.S. Army Ranger sniper who served two tours of duty in Afghanistan and wrote the authoritative “Long Range Shooting Handbook,” called the feat an “incredible” accomplishment, one that owes as much if not more to the spotter’s expertise as to the shooter's skill. “The spotter would have had to successfully calculate five factors: distance, wind, atmospheric conditions and the speed of the earth’s rotation at their latitude,” Cleckner told Fox News. “Because wind speed and direction would vary over the two miles the bullet traveled, the true challenge here was being able to calculate the actual wind speed and direction all the way to the target.” Atmospheric conditions also would have posed a huge challenge for the spotter. “To get the atmospheric conditions just right, the spotter would have had to understand the temperature, humidity and barometric pressure of the air the round had to travel through. Cleckner said that while the ammunition that Canadian special forces use in the TAC-50 is “off-the-charts powerful,” with some 13,000 foot-pounds of force when it comes out of the muzzle, the speed of a bullet, a 750-grain Hornady round, is not as important as the aerodynamic efficiency of the bullet. “The key to having a sniper round travel that far and hit a small target has less to do with speed and more to do with the efficiency with which the projectile moves through the air,” he said. That’s because while sniper bullets exit the muzzle at several times the speed of sound they eventually slow down to less than the speed of sound, and at that point they become less stable. An efficiently designed bullet reduces that instability, he explained. Dennis Santiago, California-based firearms expert and instructor, said the partnership between the spotter and the shooter is critical. "Equipment is just a starting point. The shooter on a military team will surely be skilled enough to hold hard on the 'aimpoint' and fire the shot accurately," he told Fox News. "The spotter member of the sniper team is responsible for telling the shooter the precise moment the atmospherics align with the calculations they've made. When it comes together, it's 'mission accomplished'." Source That is just insane! :floyd: |
Just don't forget... at that range, a sniper is useless without a good spotter. Props where it's due.
As time goes on, technology and skillset will only get better and better. So that record may not last too long. Someone will always be gunning (no pun intended) to beat it. The day might come where a sniper kills a target from 3 or more miles away.
At 3 miles, the arc required would make it more like a small caliber artillery round. :beercheers:
If my math is right, using this calculator, this team would have had to compensate for a drop of over 800 feet. The bullet on target would be moving around 894FPS and carry 1,330lb.ft. of energy with it. Approximately 3 to 4 times the amount of energy delivered by a 9mm round at point-blank range. From over 2 miles away.
.50BMG is a heck of a round, used for a truly amazing shot! |
| All times are GMT -6. The time now is 05:54 AM. |
