Why Don't You Have Nitrous???
#21
Well, as you said, its illegal here. Talked to the local police, and the nitrous has to be unhooked as well as solenoid wiring and some other stuff... complete garbage, but its a small town, and word that someone has put on nitrous/turbo/etc. goes around fast... they follow my GSX everywhere. They already follow the Tib enough...
I'll probably get it after all the bolt-ons if I still feel a little need for some added fun.
#22
I haven't really given it much consideration but certainly the power increase for dollar outlay is very good. If it weren't illegal for street use I would be much more likely to get it.
#23
Simply because I'm too lazy to get it out of my basement and spend a few hours to install it
It should be done by the end of June though.
And I wanted to add that FordFasterr was running 90 shot on his custom kit with a new fuel pump and colder plugs on his beta1 J2.
I also, plan on hitting 13s with my nitrous kit. Seeing that I'm running flat 15 with I/H/E and I plan on adding a few more things, and then adding 80 maybe 90 shot with my NX kit, I definitely see myself in mid 13s if I get traction right!
#24
QUOTE (paperstsoapco @ May 25 2005, 05:20 PM)
well i dont really plan on drag racing, and i dont really see the point of gettin nitrous otherwise.
had it... got sick of filling up bottles.... went to a big turbo instead.... i think i mad the right choice
#27
It's usually $3-3.50/lb. There should be someone in your town that sells it. Not every shop does, but more and more are doing it these days.
A 10lb bottle should last about 10 runs on a 50 shot.
#30
QUOTE (JonGTR @ May 25 2005, 04:52 PM)
The -11 refers to the gap size. You can gap it yourself. The -11 usually isnt available in my area, so I just get the standard plug.
well i can almost guarantee that bkr6e-11 is near you
go to a nissan dealership ask for part number
22401-50y06
list is 1.92
if you want the stock heat (bkr5e-11)
ask for 22401-50y05
list is 1.92
hehe i work for nissan
i cross checked the ngk part number to nissans
