Spraying info I couldn't find
If you are at WOT, can you flip the activation switch to spray? Is it safe, how will the car react?
Is it better to Activate, and then go into WOT? Thanks in advance for clearing this up. |
Originally Posted by hyundairacer58
(Post 640247)
Is it better to Activate, and then go into WOT? Thanks in advance for clearing this up. Activate then go into WOT. You also want to make sure your bottle pressure is between 950psi and 1100. Or else you won't get the desired effect. |
