Spraying info I couldn't find
Vehicle: 2010 Genesis Coupe 2.0T
If you are at WOT, can you flip the activation switch to spray? Is it safe, how will the car react?
Is it better to Activate, and then go into WOT?
Thanks in advance for clearing this up.
Vehicle: 2012 Ford Mustang Shelby GT500
Activate then go into WOT. You also want to make sure your bottle pressure is between 950psi and 1100. Or else you won't get the desired effect.
