SAF-C work with nitrous setup????
Hey all. Do SAFC's work with a nitrous setup... Say like, if I program it for running my car without nitrous, will those same settings work for when I spray? And if not, with the SAFC II work?
Dude this should be on the nitrous board, but yea, It will work if you do get the AFC II, you can have it memorize two setting. Therefore allowing you to run natural and nitrous. It's bad *** thinking of getting it.
[ May 05, 2003, 07:40 PM: Message edited by: EL Tiburon ]
The SAFC will tune your car for n/a, but the nitrous jets have their own tuning. They throw in the right amount of fuel and air mixture no matter what your n/a mixture is. With the right jets, you will run just as lean or rich while spraying as you were before.
Nope, you don't need it. The car will pick up some horsepower from just having the S-AFC unit tuned correctly, but it will not influence your nitrous setup.
The S-AFC is an "always on" device, and as such must be tuned for "always on" operation. Nitrous is "on demand", and as such tuning the S-AFC to somehow be optimized for nitrous use would likely kill your normal performance.
