No one using nitrous anymore?
Vehicle: 2007 Accent
I never see anyone with it? Has nitrous use been phased out pretty much except for big block 1/4 mile racers? Maybe it was only popular when Fast & Furious movies were all about street racing and blowing welds on intakes?
I have nitrous in the Genesis.
But I was using it as an IC sprayer until I put in my bigger IC this spring. Then I'll get a new intake manifold since the 1st gen IM's are unequal lengths, causing cylinder 4 to lean out if you spray and then BOOM! So need to get a better IM before spraying.
Vehicle: '14 Ford F-150
But I was using it as an IC sprayer until I put in my bigger IC this spring. Then I'll get a new intake manifold since the 1st gen IM's are unequal lengths, causing cylinder 4 to lean out if you spray and then BOOM! So need to get a better IM before spraying.Direct port.
