Hyundai Aftermarket
-   Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) (https://www.hyundaiaftermarket.org/forum/nitrous-oxide-nos-zex-nx-express-venom-etc-27/)
-   -   Nitrous mounting location help (https://www.hyundaiaftermarket.org/forum/nitrous-oxide-nos-zex-nx-express-venom-etc-27/nitrous-mounting-location-help-21236/)
javageek Aug 14, 2004 04:53 PM
Re: Clutch question
I recently purchased a NX Wet System. I have the bottle mounted on the right side of my trunk with the nozzle towards the front like directed. I have the main nitrous line running along the right side through the interior. Where should I exit the vehicle with the line? Also, where should I mount the solenoids? I have a Nitrous, Fuel, and Purge solenoid. If you could post pics of your setup that would be awesome!
JonGTR Aug 16, 2004 07:19 AM
Re: high pitched sound (radio)
I wouldn't run it IN your car. I ran mine out the wheel well and along the rail where the fuel lines go. I ziptied the line to them. I then brought the line up between the firewall and the shock tower. I mounted one solenoid there, and the other on the firewall.
Glock33 Aug 16, 2004 08:47 AM
Re: A few new engine shots after paint
here you go hahahaha
http://negativeelevations.com/module...neon%20004.jpg
Dweet Aug 16, 2004 08:56 AM
Re: Nitrous mounting location help
http://www.rdtiburon.com/index.php?name=Fo...viewtopic&t=547
there ya go.... java
REDZMAN Aug 16, 2004 09:30 AM
Re: Guess I gutta start over...
Dweet, can you edit that post to just the link for your post in the DIY section?
javageek Aug 16, 2004 10:18 AM
Re: Iceman Billet Aluminum Throttle Bodies!
Wow! That's just about everything I needed. One question though, did you drill a hole through the firewall, or use an existing one. The only one I know if is directly behind the IM and it is packed with wires already.
01tibby Aug 16, 2004 10:27 AM
Re: My car and body kit
there is supposed to be a huge opening to the left of the clutch pedal between the passenger compartment and the fenderwell.
Dweet Aug 16, 2004 10:47 AM
Re: Tib = Suck
<div class='quotetop'>QUOTE (javageek)</div><div class='quotemain'>Wow! That's just about everything I needed. One question though, did you drill a hole through the firewall, or use an existing one. The only one I know if is directly behind the IM and it is packed with wires already.</div>
The one with a bunch of wires is your wiring harness... Id stay away from that one. I drilled the hole myself. Im not scared of putting holes in the firewall. I had to drill another hole for my 4ga stereo wire
