<u>Single Nozzle Wet System Jetting</u>
<u>Nitrous Express</u> 31N/18F 35HP 35N/20F 50HP 41N/24F 75HP <u>TNT</u> 39N/22F 50HP <u>Nitrous Oxide Systems</u> 34N/18F 40HP 37N/22F 50HP 39N/24F 60HP 41N/26F 70HP 43N/28F 80HP 46N/30F 100HP 52N/33F 125HP 61N/38F 150HP <u>Single Nozzle Dry System Jetting</u> <u>Nitrous Oxide Systems</u> 34N/44F 40HP 32N/42F 50HP 34N/42F 60HP 41N/36F 70HP <u>Zex</u> 32N/36F 55HP 35N/34F 65HP 38N/32F 75HP <u>Direct Port Wet System Jetting</u> <u>Nitrous Express using 44psi @ the fuel rail</u> 20N/12F 50HP 24N/14F 75HP 26N/16F 100HP 31N/18F 150HP |
https://i45.photobucket.com/albums/f...eradam/wet.jpg
https://i45.photobucket.com/albums/f...eradam/dry.jpg <span style="font-family:Verdana Arial Helvetica sans-serif"><span style="font-size:8pt;line-height:100%"><span style="color:#ff0000">NOTE #1: 82018 system uses special jetting. Call factory for further details. </span></span></span> <span style="font-family:Verdana Arial Helvetica sans-serif"><span style="font-size:8pt;line-height:100%"><span style="color:#ff0000">NOTE #2: Fuel pump upgrade required. Use ZEX Booster Fuel Pump Kit #82020 for return style fuel system.</span></span></span> put these in because the ZEX wet shots were not in the list. |
how much of a shot of NOS would be safe/max on a stock 1.8 beta1 automatic tiburon?
Not sure if stock or not. FYI, He said:
(01:51 PM) Tony Vendetta - like what other mods? i have 4-2-1 headers complete catless exhaust, strut bad, and a cold air intake (01:59 PM) Tony Vendetta - btw I have 125k+ on my beta1 |
55hp or less is safe. Max would be 75 according to manufacturers.... Nitrous adds heat, so if your engine gets too hot, it will melt parts like your piston rings. Play it safe. I run a 55 for messing around, but sometimes I put in the 75 shot at the track. It's a simple matter of changing the nozzles.
I would not run a 75 without upgrading the fuel pump.
Where are you getting that figure? I've run it just fine.
From my wideband. Did you have a wideband on yours?
NX produces a ton more power than any other kit on the market. I've tried the NOS nozzles and they're shit. I've also found that you need to retard the timing a great deal at that point also. Not a lot of ECU friendly options for that. |
^^ The newer ZEX nozzles adjust fuel to the level of nitrous being put out. That means you'll always get the stoichometeric ratio, or close to it, no matter what your bottle pressure. That's what they claim at least. I don't see how it can get much better then that. A venturi is a venturi and they suck fuel into the nitrous stream by passing the nitrous at high velocities by the fuel.
My local nitrous shop said they've never seen a problem with anything that came from ZEX. I'm really not worried about a wideband reading. The ZEX kit self tunes. I'd like to get a fuel pressure reading while running nitrous to make sure i'm still at 36psi or higher. |
And how does the Zex kit magically know that you're leaning out? Does it include a wideband sensor? It increases fuel pressure, but without a wideband or O2 reading, it's not going to know you're running out of fuel.
