i was wondering if anybody was spraying that is using the 1.8 ecu?
i believe RD2pimp is or will be soon
i was wondering cause i have the 1.8 ecu and i want to spray and i know it advances the timing and with nitrous you want to retard timing so i didn't know how safe it would be
i was planing on hooking up my zex system in about a week. as far as the timing goes im still trying to figure that out.
i believe the intake cam retards timing 6-9 degrees im not to sure the number and the 1.8l ecu is supposed to advance your timing a few degrees havent found an exact number on the ecu yet. if anyone else is using the 1.8l cam and ecu and is trying to spray, any information you could give would be great.thanks |
