Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Intercooler Sprayer DIY
Old Mar 9, 2010 | 06:32 PM
ACCENT2.0t's Avatar
Vehicle: 1997 hyundai accent swap 2.0 turbo
Default Intercooler Sprayer DIY
Okay so most ppl have seen the Nitrous/Co2 sprayer bars on intercoolers used to cool the intercooler way down and superfreeze the intake charge resulting in denser air and more combustion if you havent heres a couple sights to buff up on the topic at hand
http://www.hondatuningmagazine.com/tech/05...test/index.html
(sorry about the honda forum i hate them too but it as a good write up)
in action
http://www.youtube.com/watch?v=VmGz29G7xpY
also homemade!!! which takes me to the topic up for discussion id like to make a homemade kit using c02 its alot cheaper and just as cold and isnt flammable and i need some ideas on how to build this kit has anyone done so or has better ideas than me... ill do a DIY for one after mines done
Old Mar 9, 2010 | 08:54 PM
The weight gained from the kit during daily driving would counteract the purpose. Unless all you care about is that quarter mile time, it would just be a fancy addition. We use CO2 for freezing warts in the medical field. It does not take much, but when you are outright spraying for an area coverage, it takes mass quantities. I'd say it would work, but water or windshield washe fluid is much more cost effective and requires no special handling.
Old Mar 10, 2010 | 10:31 AM
ACCENT2.0t's Avatar
the weigh gain i believe would be very minimal and what im really looking for is ideas of how to make it happen
Old Mar 10, 2010 | 10:53 AM
JonGTR's Avatar
You could spray the equivelant of a 150 shot over your radiator and get maybe 10hp?
Or, you could spray a 25 shot in your intake to cool it down just as much, and gain like 35hp.
I'm just throwing out estimated numbers, but you get the idea. Which sounds much cheaper?
Old Mar 10, 2010 | 11:54 AM
ACCENT2.0t's Avatar
not over the radiator over the intercooler but you get the idea its to super freeze the charged air going through the ic and nitrous in the motor still scares me sad.gif and this isnt a drag car either so if you get caught with an active bottle=trouble
Old Mar 10, 2010 | 12:16 PM
JonGTR's Avatar
oops, i meant intercooler. Thinking one thing and typing another.
A 25 shot isn't going to kill anything.
Old Mar 10, 2010 | 12:18 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
listen to gongtr,
Old Mar 10, 2010 | 12:19 PM
i love how people are willing to turbo there car...but are afraid to run nitrous
NITROUS DOESNT HURT ANYTHING AT ALL RUNNING LEAN DOES HELL ITS NOT EVEN FLAMMABLE
if you are turboed you SHOULD have a wideband anyways
Old Mar 10, 2010 | 02:33 PM
How to make it happen:
buy a nitrous purge kit, route the purge to the intercooler. Change the fittings to fit a co2 bottle and then fill up the tank for around 50 per bottle and waste $200 plus $40 per fillup.
Or:
pick up a windshield washer sprayer from the junk yard and route lines the same way from your washer tank and save a Ton. Water is nearly free and while not quite as effective, still works well. This system is used on 2003 and below Mitsu Evoloutions. After 2003 it is automatic based on intake charge temp.
Old Mar 10, 2010 | 02:55 PM
ACCENT2.0t's Avatar
i dont want a puddle of water like those half ass subbies on youtube and have ppl thinking my cars leaking coolant and nitrous or co2 would be way colder than water and i didnt mean afraind to do a nitrous shot but itd be pointless bc i dont go to the track and its illegal to have a bottle in the car on an active line so thats why i said co2 which is nearly as cold and would have equal effects not to mention its like 4 bucks to get a refill at a paintball store so thats no problem good advice on the water thing but id like to know how to get this system with co2
