Inline fuel pump boosters
What do you guys think about using one of these inline boosters with the stock pump instead of using a larger flow pump like a walbro?
http://www.zex.com/zx/efi-booster-fuel-pump-kithtml/ http://www.zex.com/media/catalog/pro.../82020_600.jpg Details Fuel system upgrade provides the potential to boost your fuel system flow capacity up to 650 HP, even on high fuel pressure turbo, supercharged & nitrous applications Installed In-Line, So No Dropping Your Fuel Tank Kit Includes Pump, All Hoses, Hose Clamps, Wiring, etc. Necessary For A Clean & Easy Install For Return-Style Fuel Systems Only |
It is cleaner, less work, and probably cheaper to just swap in a 190lph walbro.
I would be too nervous of that failing in the middle of spraying and your engine going boom!
