Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
EGT drop
Old Dec 19, 2011 | 02:23 PM
Ghost Shark's Avatar
Vehicle: 99 Tiburon
Default EGT drop
I have heard that your EGT drops while spraying. How much does it drop and is there anything I should watch out for or be careful of when it does drop?
Old Dec 19, 2011 | 05:55 PM
It depends on how lean you are running before you spray...how much you spray...if you're spraying "dry" or "wet"...etc..etc..etc...
In other words..it depends.
In general, lower EGT's are fine, as long as you don't drop more than 200-300F from normal WOT EGT Temps. If it does drop that much, you're spraying WAY too much N20 or Fuel.
If your EGT's go up...you're spraying too much N20 and/or not enough Fuel...your gonna do some serious damage quickly, stop and use a smaller nozzle or more fuel.
