Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Direct Port?
Old Jan 30, 2004 | 12:07 PM
Twisted385's Avatar
Vehicle: 2000 tibby
Default My Bad
Ok, I am kinda new to using nitrous. But here is the set up I am planning on. Either purchasing another stuck manifold or purchase the one from importshark. Tap the runners for a direct port setup. If I do this, what type of "shot" could I safely run on stock internals? I am planning on upgrading fuel pump, and injectors as well. I already have a BBTB and intake. Also a few other things, that are not related to this setup.
Old Jan 30, 2004 | 01:12 PM
JonGTR's Avatar
You don't need injectors. The only things you need other than the kit are the Walbro, a standalone FPR to control it, and the right spark plugs for the shot you are running.
You can run an 80 shot with this, but I would recommend getting a controller for anything higher for traction/shock issues. After that you should be able to run around a 100 shot safely.
