Cool nitrous set up
https://farm3.static.flickr.com/2441...f885f9b9_z.jpg
https://farm3.static.flickr.com/2169...a44d7d3d_z.jpg Not sure why you would need the 2 smaller bottles or what purpose they even serve but it's a clean set up. |
That's a lot of weight. 1 five lb bottle hidden where the spare tire used to be would be way cooler in my opinion.
My nitrous setup back in 2003:
https://img.photobucket.com/albums/v...tch_Area_2.jpg http://img.photobucket.com/albums/v2...tch_Area_1.jpg |
Whats the point of having 2 large bottles and 2 little bottles? Do they all feed into each other for a steady stream of nitrous? Couldnt you just get one bigger bottle for the same effect?
Because show > go.
Not a fan of the all show set ups. I like a clean basic type like this
http://www.enginebasics.com/Advanced...0Oxide%204.jpg |
^ Thats the type I would go with too. Maybe even a smaller bottle than that but I know it wouldnt last long. Couple of shots and thats it.
Originally Posted by Cereal Killer
(Post 705763)
http://www.enginebasics.com/Advanced...0Oxide%204.jpg You also need a blow-down tube as the original post shows. The bottle opener is a plus for street use, but not required when running at the track. I don't care for Zex. They tend to overly complicate things with what should be a simple system. The more gadgets you have, the more that could go wrong. |
^^bottle blanket needs to be added to the list
