Hyundai Aftermarket
-   Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) (https://www.hyundaiaftermarket.org/forum/nitrous-oxide-nos-zex-nx-express-venom-etc-27/)
-   -   Bottle position (https://www.hyundaiaftermarket.org/forum/nitrous-oxide-nos-zex-nx-express-venom-etc-27/bottle-position-80316/)
Twisted385 01-05-2016 03:52 PM
Bottle position
Is it acceptable to mount my bottle (10lb) transversely behind the passenger seat, as this would appear to be the best way to get it in my car...
I know the installation manual says to mount with the neck facing forwards, and I can see the theory behind this, but is it possible to do the above (obviously maintaining the correct angle on the bottle mount etc...)
Help needed!!
DTN 01-05-2016 04:55 PM
It is always possible to do anything. However when your bottle gets low your nitrous will become sporadic and your engine will suge/bog when the nitrous hits and moves away from the tube.
JonGTR 01-06-2016 06:19 AM
By the time it gets low enough to matter, your pressure is below optimum. I don't think you'll have a problem. The important part is having it angled upwards.
i8acobra 01-06-2016 06:29 PM
With the bottle front to back, as you accelerate, the nitrous is pushed towards the pickup. Sideways, the nitrous is pushed away from the pickup. If you don't run a bottle heater, JonGTR is correct... probably be low on pressure before it's a major problem. If you do plan on running heater, you'll have good pressure until you're almost out, so I'd definitely only run it front to back.
