Genesis Coupe High Flow Cats, Resonated Test Pipes, and Catless Test Pipes
Vehicle: 2011 Optima
Good day everyone, hope you all are well.
We have released 3 versions of test pipes for the Genesis coupe 3.8. Each of these pipe sets come with all the necessary hardware you need to install them. These re-use the stock gaskets. All of these are 100% hand made in the USA from materials made and sourced in the USA.
We build everything to order here so our lead time is 3 business days from the day you order. Unfortunately that is the price we have to pay for hand building everything here in La Center, WA.
First up are the high flow cats. These use a Magnaflow 200 cell metallic core catalytic converter. One of these cats is designed to clean the air of a 6.2 liter engine, so these are fine for passing emissions testing.
Next is the resonated test pipe. These are built using the mufflers we build right here in our shop. They are 2.5" ID and use a proprietary packing material that is good to temperatures in excess of 2700 degrees Fahrenheit. The entire muffler including the perforated tubing inside is made from t304 stainless steel to resist corrosion. These give you the power of straight test pipes while taking some of the rasp out that you normally get with test pipes.
Last we have the standard test pipes. These are t304 stainless steel straight tubes welded to flanges and bolt directly into your Genesis Coupe.
Enjoy!
Thank you,
John Hoyenga
President, Nameless Performance Inc.
360.263.5001
Enjoy!
Thank you,
John Hoyenga
360.263.5001
