Hey guys, Im wanting to put through an order but would like a couple questions answered first if you dont mind.
I'm looking to get a Koyo rad, however it does not say that it's a fit for a 1997-1999 rd. I have a 1998 will it fit with little work or should I expect custom fitting? Your shifter base bushings are just for the Tiburon correct? Or are these some what universal? Lastley I'd like a shipping quote to Ontario, Canada for the rad, base shifter bushings, and delerin bushing. Thanks for your time, |
I can answer a few of these for you.
1. Koyo - FITS PERFECTLY. A quick use of the SEARCH FUNCTION will show you that. 2. The shifter BASE BUSHINGS will fit the RD's, and any car that uses the same shifter base setup, to include the GK's/XD's. |
Hey,
Thanks REDZ. Our base bushings as well as our delrin shifter bushings are made specifically for the tiburon and elantra. They are not universal pieces. holeshot, I sent you a PM with a quote for all of the above. Thanks, Kevin KJB Motorsports |
