Welcome To The Forums: Deegatron
Old Oct 15, 2009 | 01:15 PM
RD Greeter's Avatar
Member Name: Deegatron
Registered on: Oct 15 2009, 03:15 PM
Profile: http://www.rdtiburon.com/index.php?showuser=9919
Deegatron,
Hi, my name is ____.
I'm from ______.
I drive a ______ _____.
__
____
_
_____
Old Oct 15, 2009 | 01:54 PM
Deegatron's Avatar
Hi, my name is Jon.
I'm from edmonton alberta Canada.
I drive a 2003 base model tiburon silver
I found these forums through newtib and some buddies with rdtibs
Aem CAI
Shark racing 4-1 header w stock cat modified to fit w 4 EGT bungs (3 are capped)
ARK single exhaust
DIY polyurethane motor mounts
KYB struts
Eibach rear swaybar (front one is useless)
glowshift EGT, oil pressure, and vac gauges in custom pod below cd player
aluminum shift plate with custom narrow band A/F gauge
performance shift bushings and aluminum shifter base bushings
Enkei rs-7 17" wheels with bf goodrich g-force sport tires
blue gauge cluster conversion including turn signal lights
custom box with 2 alpine 10's and an alpine 900watt digital amp.
alpine head unit.
SAFC-II
mod's i've done and since removed
eibach front swaybar
adjustable swaybar endlinks
quest coilovers
mod's waiting to go in
motor teardown and rebuild in progress on spare motor
fidanza flywheel
fidanza cam gear
clutchmasters stage 1 clutch kit
Old Oct 15, 2009 | 04:21 PM
welcome
Old Oct 15, 2009 | 04:38 PM
TibFreak's Avatar
Welcome, now where are the pics?
Seems to be alot of you guys coming over from newtiburon.com
