Heya, I'm new!
<div class='quotetop'>QUOTE (2Bits)</div><div class='quotemain'>Hey welcome, Redz anything u dont know??</div>
Tons.
LOL
I've got a huge mellon and read alot. I just remember some stuff.
Doing a search recently on HA.com I saw that most of the pictures are old and GONE, if someone can get some pictures of the firewall holes, I'd appreciate it.
Tons.
LOL
i did what joe suggested.
cut a little hole in that plug right behind the Throttle Body. wrap whatever you need to fish through with a "unravelled" coat hangar. then just push it through. it would be a good idea to take off the plastic panel that covers the bottom of the steering column and contains the dimmer switch, so you can grab the wire.
two screws at the bottom of it, pop out that little tab at the top right to expose another screw. to get to the other one, i get some needle nose pliers, grip the dial of the dimmer switch, then gently pull on it untill it pops out.
use www.hmaservice.com/webtech for everything!!!!! just spend some time looking through it, the thing is great.
heres some quick pics of the spot i snapped.
