Engine & Turbo upgrade
Hi I am Viceroy and currently drive a 1995 Hyundai Accent 1,5 Csi that is turbo charged.
I want to upgrade the motor to 2.0L and Turbo it. Which motor can I use & is there a motor that I can still use my origenal gearbox. |
You'll want a 2.0l Beta I engine from a Tiburon or Elantra. You will find them in Tiburons 2001 and older and Elantras 1996-2000. It will bolt to your transmission. The Beta ECU will even plug into your wiring. There is also a 1.8l Beta I so you have to verify that you are getting a 2.0l.
welcome.gif to the site! There are a TON of Accent owners here, and a bunch that have the engine swap that 187sks mentioned. We can definitely help if you have any other questions about it. smile.gif
