Door panel
Old Jun 14, 2004 | 03:06 PM
paperstsoapco's Avatar
Ok i feel like a complete moron so this goes into the newb section. I tried removing my door panel today. i took out all of the screws and what not and tried liftin it off and it seemed to get stuck at the base of the rear view mirror. what am i dong wrong, wtf is wrong with me? thanks for the help
Old Jun 14, 2004 | 03:29 PM
canadianshark74's Avatar
you mean the side view mirror,
just pull that little triangle thing off. it makes it easier to pull the panel up
Old Jun 14, 2004 | 03:35 PM
yeah, pop the triangle thing off...
also make sure you unscrew the screw holding in the door handle.
Old Jun 14, 2004 | 03:37 PM
4U2enV's Avatar
if you wanna bigger pic go to http://www.cardomain.com/memberpage/556562/3
but i think your prob. is that piece i outlined in green.
Old Jun 14, 2004 | 07:12 PM
ahhhh, makes so much more sense, thanks a lot guys
Old Jun 14, 2004 | 08:00 PM
zoned019's Avatar
Vehicle: 97 Tib
Default CF Hood from importfan
yeah, probably the screw in the door handle.
Old Jun 14, 2004 | 08:04 PM
MADTIB's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>just pull that little triangle thing off. it makes it easier to pull the panel up</div>
Don't really have to do that.just slide the panel to the rear until the window seal lets go from the top edge of the door.Also,it makes it easier if you roll the window down first.That goes same for re-installation too.
Old Jun 14, 2004 | 08:05 PM
MADTIB's Avatar
<div class='quotetop'>QUOTE (joe_the_canadian)</div><div class='quotemain'>
but i think your prob. is that piece i outlined in green.</div>
The 3 screws at the bottom don't have to be removed!! These simply attach the map pocket to the door panel.They have nothing to do with securing the panel to the door.
Old Jun 14, 2004 | 10:02 PM
Madtib, it shows that in the pic.
Old Jun 14, 2004 | 11:32 PM
4U2enV's Avatar
<div class='quotetop'>QUOTE (MADTIB)</div><div class='quotemain'><div class='quotetop'>QUOTE (joe_the_canadian)</div><div class='quotemain'>
The 3 screws at the bottom don't have to be removed!! These simply attach the map pocket to the door panel.They have nothing to do with securing the panel to the door.</div>
yea after countless times removing my door panels i finally figured it out,but it does say it in the pic tongue.gif
