A wiring quesiton
Old Sep 9, 2013 | 06:02 PM
flamewoo's Avatar
Vehicle: 2007 Accent
Default A wiring quesiton
Got a Rockford Fosgate 801S Specs say 200 watts x 2 4 ohm stereo, 800 watts 4 ohm mono, or 2x400 2 ohm stereo
So, If I run a single voice coil sub, run the negative on one channel, the positive off the next, then I would be getting 800 watts in 4 ohm mono with a single voice coil 4ohm sub? Because for some reason, I was thinking you either had to run 2 speakers or more, or dual voice coils to achieve mono mode.
Old Sep 9, 2013 | 08:43 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Yes.
According to the 801s manual, you use the left channel positive and the right channel negative. Be sure both left and right gains are set the same:
http://www.rockfordfosgate.com/rftec...nch2ch_MAN.pdf
