Wiring!?
Old May 4, 2001 | 03:02 AM
DESIGN's Avatar
Simple fix: Go plug your old ones in and you will be able to tell which one is + and which is -. Hopefully you haven't already ditched the conectors.
Old May 4, 2001 | 10:36 AM
:: skilspeed ::'s Avatar
Use a multimeter or a signal tester. Attach the negative prong on the tester to a ground on the car..(most chassis bolts) and the other to each wire (NOT each speaker wire at the same time). The tester will tell you which is positive.
Also, ground is usually black or brown. I can't remember when I put my speaks in what color it was. Positive is usually red or white. If you have any other colors..um, then the koreans skimped on some parts.
Or you could guess (i don't recommend it though)
[ May 04, 2001: Message edited by: ::[aeliux]:: ]
Old May 7, 2001 | 06:45 AM
Jaws99's Avatar
Just make sure by doing this that the front speakers are not now out of phase from the back ones. Fade to the back since you know they sound right begin fading to the front if you start to loose volume or they begin to break up then the fronts are out of phase. Even though the back might sound right they might be negative to positive and the fronts positive to positive.
