Hyundai Aftermarket
-   Interior, Sound, Security (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/)
-   -   Stuck Pedal (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/stuck-pedal-15526/)
silverstreak Sep 9, 2009 07:21 PM
Stuck Pedal
The throttle is stuck, why?
faithofadragon Sep 9, 2009 07:26 PM
well its a cable...so check for it binding on something
silverstreak Sep 9, 2009 07:31 PM
Thanks, what should i look for?
faithofadragon Sep 9, 2009 07:43 PM
well there is a metal cable that goes from the pedal through the firewall over the valve cover and to the throttle body
is it stuck open or stuck closed?
03AccentVA Sep 9, 2009 11:23 PM
If that doesn't work & you have cruise control, try pulling the fuse for the cruise control. That happened in my Crown Victoria (Pedal stuck @ full throttle while going down the highway).
silverstreak Sep 10, 2009 01:49 PM
<div class='quotetop'>QUOTE (03AccentVA @ Sep 10 2009, 01:23 AM) <{POST_SNAPBACK}></div><div class='quotemain'>If that doesn't work & you have cruise control, try pulling the fuse for the cruise control. That happened in my Crown Victoria (Pedal stuck @ full throttle while going down the highway).</div>
It's a Hyundai.
187sks Sep 10, 2009 02:06 PM
Hyundais aren't magically 100% immune to conditions that happen in other makes.
You still didn't answer whether the pedal is stuck open or closed. It makes a huge difference on what might be wrong with it.
Fintile Sep 12, 2009 09:32 PM
ALso clean it. With it off use a small amount of brake cleaner just a spray and wipe the edges of the butterly fla and inside the TB itself. I had a BBTB a while back and it would stick closed on me sometime keeping me from smoothly driving.
