Stuck Pedal
If that doesn't work & you have cruise control, try pulling the fuse for the cruise control. That happened in my Crown Victoria (Pedal stuck @ full throttle while going down the highway).
Vehicle: 2002 Hyundai Elantra GLS
QUOTE (03AccentVA @ Sep 10 2009, 01:23 AM)
It's a Hyundai.
Hyundais aren't magically 100% immune to conditions that happen in other makes.
You still didn't answer whether the pedal is stuck open or closed. It makes a huge difference on what might be wrong with it.
ALso clean it. With it off use a small amount of brake cleaner just a spray and wipe the edges of the butterly fla and inside the TB itself. I had a BBTB a while back and it would stick closed on me sometime keeping me from smoothly driving.
