Remove Seatbelt
Hey does anyone know to to remove the seatbelt from the front seats? I am trying to get the plastic piece around that off but I can't unless the seatbelt comes off also.
Remove the seat and it will be easy.
<div class='quotetop'>QUOTE (DTN @ Sep 27 2010, 07:55 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Remove the seat and it will be easy.</div>
What do you mean? I'm talking about the highest plastic panel. The one after the A pillar. |
He's talking about
<div class='quotetop'>QUOTE (AtomicX @ Sep 27 2010, 06:53 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Hey does anyone know to to remove the seatbelt from the front seats?</div> banana.gif I seem to recall it involves taking off half the interior trim to get to where you can remove the B pillar panel |
^^^ Yup. Been there done that. You have to take off the plastic surround (I think you may have to remove a couple others as well to get to it? Been awhile...). Once that is off, then there's just one or two bolts holding it off. Comes off really easy then.
It's not terribly hard, even with any other bits that you may have to take off. |
Easyiest way to remove the back seast, take off the back piece around the triangluar window, then take off the speaker cover, undo those few bolts, once the bottom part of the back seat is out, you will see one hidden bolt, then your seimple pill off, as it has a few snaps on the back side to hold it in place! back seats come out with like 4 bolts and a few tugs!
| All times are GMT -6. The time now is 05:30 AM. |
