Rear floor is getting wet
Can someone tell me what could be causing the floor in the back seat get wet when it rains out? I looked under the car and there are no holes or anything that might let water in. Where else could it be coming in from?
It's coming from the top. The best possible scenario is you have a stick jammed in the seal around the hatch. Worse, your gas could be leaking. Worst case your rust is leaking.
