question about grounding multiple amps
Old Jan 9, 2014 | 06:28 PM
sam's Avatar
sam
Vehicle: 08 Sonata
Default question about grounding multiple amps
Hey guys, I need some advice on grounding multiple amps. Right now I've got an Alpine MRV-M500 powering a 12 inch Kicker L3. I'm going to get an Alpine MRV-F300 for mids and tweeters in the near future and just want to clear this up so I'll know what to get.
I have a (supposedly) 0 gauge CCA cable (i think) which will go to a distribution block and split into 2 4 gauge wires (hopefully will fit the F300).
Now here's the question: should I do the same thing with the ground ? the 2 4 gauge ground wires from each amp to a distribution block and my current ground cable (also 0 ga of course) ? Or should I ground the 2 amps to the same spot without the distro block and without the 0 ga ground cable ? I know that you're supposed to have the same thickness of power and ground cable...
Old Jan 10, 2014 | 07:15 AM
Red Raspberry's Avatar
As long as the actual in and out wires are the same size that is what matters. The shorter the run the better.
I like using one of these for a ground block. as it grounds to the frame also.
Old Jan 10, 2014 | 11:46 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Worked fine in my 350Z:
Old Jan 10, 2014 | 04:40 PM
songee623's Avatar
Vehicle: 2005/hyundia/elantra
power and ground blocks are what ive used in many builds
