Painting woofer cones
Vehicle: 1998 Tibby
Is there a way to paint woofer cones so it matches your cars paint? How would you do it without it cracking due to the vibration and movement?
Off the top of my head: If it's unsealed paper, a light spray painting would probably be okay and last pretty well. If it's sealed paper it might still be fine. For plastic, you'd need a plastic-specific paint and I expect results might vary depending on the chemistry. Don't paint the surrounds, both because it might dissolve the surround and because it'll probably flake off.
