No Power Door Actuator Harness
Old Mar 13, 2008 | 08:36 AM
I've looked no luck because my problem isn't the door actuators, it's the harness. I've replaced both actuators with brand new OEM Hyundai ones. Door lights don't work either with new bulbs. I've tested the door light sockets with a voltmeter and 0 power. The window switches work fine and so do the powered mirrors but the door lock harness has no power.
It could be a bad circuit, but what could cause the circuit to go bad? And where is the circuit located, can it be replaced?
Anyone have any similar problem? I know I'm not the only one. As usual in my other threads I'm grateful.
bumping this for update before i put my door panel back for good.
-Right bulb works, but the plug has no power.
-Left bulb doesn't work, but the plug has power.
all fuses fine inside and out. i just can't seem to understand what is wrong. short circuit?
what is this "Diode Z12" on the upper lefthand side?
Old Mar 15, 2008 | 09:21 PM
bumpety, if anyone know anything about this it would be dandy.
Old May 2, 2008 | 03:41 PM
my mechanic found it. since there was no mudguard in that area (left it off because of working on the evap) the connector would rattle against the metal cutting half of the wires and even a big hole in the plug!
don't leave your mudguards off!! that's one problem fixed out of 5.
Old May 2, 2008 | 04:20 PM
Sweet. I never even saw this thread... wierd.
Old May 2, 2008 | 10:06 PM
yeah DTN! water got in there too. check out the huge hole it blew in the connector. just look at the damage:
remind me never to work for NASA.
