NEONS!!
Old Jul 24, 2009 | 08:27 PM
Lynchie's Avatar
Vehicle: 1996 Hyundai Excel
Default NEONS!!
How do you set up neons 4 the interior of ur car? i.e., where do u wire them into?
Have an Excel GX, 1996 model.
...Lynchie
Old Jul 24, 2009 | 08:45 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
the battery where else. wire them to a switch and add an inline fuse and you"ll be set to go
03AccentVA's Avatar
Vehicle: 2003 Hyundai Accent
I did pos behind the fuse panel (cig lighter fuse turns on/off with my car) and ground to the bare metal anywhere (as long as it's grounded and hidden).
Old Jul 25, 2009 | 03:00 AM
Lynchie's Avatar
Oh ok i can wire them into the fusebox... the inernal one or the external one (near the engine)?
Old Jul 26, 2009 | 08:37 PM
im telling you the best way is to run them to the battery and then go through the fire wall and your already behind the dash that way. and then just run the wires to desired switch location and then to the neons. its a little bit more tedious of a job but it keeps all the wires tucked away.
Old Jul 26, 2009 | 10:09 PM
I say find a switched hot (only hot when the key is on) spot on the internal fuse box with a 10A fuse and go from there. If you go straight from the battery the lights will stay on if you turn the car off.
Old Jul 27, 2009 | 07:16 AM
Lynchie's Avatar
oh ok then, that pretty easy i know how to do that. 10A il give it a shot, id rather not play aound witht he battery if i can help it. might kill myself
Old Jul 27, 2009 | 06:43 PM
you cant kill your self with 12v my friend. you must have skipped high school science. and you cant even shock yourself. and if you wire them to switch they wont be on at all times. only when you want them to be.
Old Jul 27, 2009 | 08:26 PM
Steezy's Avatar
Vehicle: 99/Hyundai/RD1
I would suggests Cold Cathodes instead of Neons.. I've heard they last longer and are brighter.. I have them under my seats and i wired them to my fusebox.. i have no problems.. i got the cathodes from http://www.xoxide.com/coldcathodes.html incase you're interested.
Old Jul 28, 2009 | 01:43 AM
QUOTE(omeletduefromage @ Jul 27 2009, 05:43 PM)
