Gauge cluster removal
How in the world do you take the cluster out. I am trying to put in some of the reverse glow gauges but i can not figure out how to take everything off to get to it.
Step 1. remove dashboard. This involves taking off the shifter surround, radio surround, and upper and lower dash.
Step 2. Once you get all that off, you will be able to see how easy it is to get the gauge cluster out. There's like 4 screws, unscrew em, unhook it from the harness, pull out (actually I think it might unhook itself when you pull it out).
Step 3. Unscrew the little plastic window.
Step 4. Install gauges
Step 5. Put everything back
If you need more in depth info on how to get the dash off, LMK. Its a whole buncha screws and unhooking harnesses.
I know Hyundai Web Tech has a pretty detailed set of instructions on this. The link is Clicky Here
That up there is excessive and unessesary. You dont need to remove the steering wheel or the center console. And they don't tell you about the hidden screws. lol.gif
