Chassis ground vs cable ground..
Vehicle: 2004 Tib - Beta
interesting video highlighting the difference in voltage drop when using chassis ground or cable ground..
http://www.youtube.com/watch?v=_Bpdh2BD-qI
I just ran a ground to the trans from my trunk mounted battery. You can tell the starter spins faster.
Left all the factory grounds where they were. The major ground from the trunk battery is to a set belt anchor bolt and a ground buss mounted on the inside trunk wall. So I added a 6 ga wire from the ground buss to the factory trans ground point.
