Hyundai Aftermarket
-   Interior, Sound, Security (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/)
-   -   Bros Gauge Faces (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/bros-gauge-faces-26684/)
col96fx Feb 22, 2005 05:50 PM
Bros Gauge Faces
I just received my new gauge faces from k-spec and wanted to know if there is anything to be careful of when doing the change. It doesn't look to hard and I can follow the pics in the instructions, but I can't read Hangul so I just wanted any info that might help from those of you that have done it b4.
Sparticus Feb 22, 2005 05:53 PM
leave the plastic piece covering the faces off at first. you wanna drive around and make certain that your needles are accurate. you don't wanna put everything together, get on the road and find out the needles aren't right.
don't push on the needles too hard when re-applying.
01tibby Feb 22, 2005 09:58 PM
are you gonna cut up the stock faces like it says?
heres a thread with info. on how to calibrate needles if you even do take them off.
col96fx Feb 22, 2005 10:15 PM
<div class='quotetop'>QUOTE (tibby01)</div><div class='quotemain'>are you gonna cut up the stock faces like it says?
heres a thread with info. on how to calibrate needles if you even do take them off.</div>
From the instruction pics it looks like they cut the old faces to remove them and then slip the new faces on with the needles in place, but I was going to remove the needles and try to keep the old faces in tact. What info were you talking about confused.gif
KayJai Feb 22, 2005 10:22 PM
<div class='quotetop'>QUOTE (col96fx)</div><div class='quotemain'>From the instruction pics it looks like they cut the old faces to remove them and then slip the new faces on with the needles in place, but I was going to remove the needles and try to keep the old faces in tact. What info were you talking about confused.gif</div>
Yeah, that's correct, when I got mine, I got mine LONG time ago from Rick and there were no instructions, so I didn't cut the OEM faces, and just took them off and applied the BROS ones, so I had to re-cal the needles, but no biggie.
I had access to a scan tool and hoist, so we just hoisted up the front end to calibrate the speedo needle and rpms
Fill your gas to full so you can just put the needle on "FULL" and run your car for a good half hour so you can put your temp needle in the middle so it's at "operating" temp.
turbotiburon Feb 22, 2005 10:43 PM
<div class='quotetop'>QUOTE (KayJai)</div><div class='quotemain'>Yeah, that's correct, when I got mine, I got mine LONG time ago from Rick and there were no instructions, so I didn't cut the OEM faces, and just took them off and applied the BROS ones, so I had to re-cal the needles, but no biggie.
Fill your gas to full so you can just put the needle on "FULL" and run your car for a good half hour so you can put your temp needle in the middle so it's at "operating" temp.</div>
anyone got pics?
col96fx Feb 22, 2005 10:47 PM
KayJai Feb 22, 2005 11:02 PM
WHat do you mean the only go on one way???
The pop off and you push them back on.
Can't find any pix online right now,...
EDIT: Found some
http://www.rdtiburon.com/forum/vbgar...etimage&id=282
http://www.rdtiburon.com/forum/vbgar...etimage&id=283
Mine are 1st gen of the BROS gauges If you go to KSPEC you'll see the current ones
http://kspec.com/list.php?ac_id=98&ai_id=801
01tibby Feb 22, 2005 11:21 PM
http://www.rdtiburon.com/forum/showthread....ght=calibrating
Lil Tiby Feb 23, 2005 08:19 AM
Yup everything's been answered. But when I replaced my gauges I removed the stock ones completely. Post pics when you have them installed.
