Bridging an amp.. Question about ohms
Old Feb 23, 2005 | 08:03 PM
iamcyclopseatme's Avatar
Default Bridging an amp.. Question about ohms
Ok.. So I always thought if you bridged an amp (2 channels, 4 ohm each), that the 1 combined channel would be 4 ohms and If you had 1 sub w/ 4 ohm VC, it would run at 4.. I just recently heard that if you bridge 2 channels, it will drop the ohms to 2..
Is this correct?
I thought I had most of this stereo shit figured out, but something always comes up ;/
Old Feb 24, 2005 | 09:00 PM
Solo-Baric's Avatar
some amps stay at 4 ohms and some drop to 2 ohms. you need to do some research on the amp you have to figue it out.
