Alarm Wiring
I found a wiring diagram for a 00 tib it should be the same for the 01 right? Im ganna takle my alarm this weekend and just wanted to make sure before i dig into it. Thanks
im pretty sure 100 percent the same. even if it isnt, noe of the different wires would affect an alarm install.
well i just wanted to make sure so i wasnt looking for a wire that wasnt there or something. Ive got a list of all the wires needed and the color and location to hook alarm right up so i just wanted to make sure. Thanks a ton!
Check out www.bulldogsecurity.com, they have wiring diagrams for just about every car.
Here's another http://www.designtech-intl.com/Content/home/
if you bought the alarm from a stereo shop they should have given you a diagram for your specific car.
<div class='quotetop'>QUOTE (solo-baric @ Apr 3 2005, 02:22 PM)</div><div class='quotemain'>if you bought the alarm from a stereo shop they should have given you a diagram for your specific car.
<div align='right'><{POST_SNAPBACK}></div></div> i didnt. Got it online to save a crap load of money! But i did get it installed and works great. Now all i need is a actuator for the driver door and a trunk kit and all will be good! Thanks all for the links! They helped out a lot! |
good luck getting the actuator to work for the hatch. It's going to have to have a lot of pull.
i dont think he was going to use an actuator for the trunk. he said he needed a trunk kit. atleast i hope he wasnt thinkning of using an actuator for it.
<div class='quotetop'>QUOTE (tibby01 @ Apr 6 2005, 02:51 PM)</div><div class='quotemain'>i dont think he was going to use an actuator for the trunk. he said he needed a trunk kit. atleast i hope he wasnt thinkning of using an actuator for it.
<div align='right'><{POST_SNAPBACK}></div></div> Nope im ganna use a trunk kit but i need to get an actuator for the driver door! |
