2000 Stereo Radio Harness Wiring Guide
Old May 9, 2009 | 03:57 PM
enigo's Avatar
Vehicle: 97 Tiburon Fx
2000 Hyundai Tiburon Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Green/Black
Left Front Speaker Positive Wire (+): Red/Yellow
Left Front Speaker Negative Wire (-): Red/Black
Right Front Speaker Positive Wire (+): Green/Yellow
Right Front Speaker Negative Wire (-): Green/Black
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Blue/Yellow
Right Rear Speaker Negative Wire (-): Blue/Black
Taken from (after much searching):
http://www.modifiedlife.com/2000-hyundai-t...wiring-diagram/
Old May 9, 2009 | 04:46 PM
The only problem with that: Hyundai uses whatever color they feel like sometimes. For most cars, for a general guideline:
Big, red, always has +12V: 12V power source
Yellow/Orange, has 12V when the key is on: auxiliary (switched) 12V
Black, 0 ohms to a metal part on the chassis: ground
Blue: possibly antenna/remote wire
A pair of wires the same color, with one or both wires having a stripe of some kind: probably speaker wires. Touch the terminals of a 9V battery across them and the appropriate speaker will click loudly
Old May 9, 2009 | 10:17 PM
I believe the DIY section has a scanned diagram of the wiring schematics for this.
Old May 11, 2009 | 10:29 AM
enigo's Avatar
Thanks for the tip Stocker! Didn't think of that.
REDZ, there is a diagram, but apparently the 2000 is significantly different from the 2001 as far as wire colors go.
As it turns out that listing isn't quite correct... at least for my 2000 tiburon.
Car Radio Switched 12v+ Wire: Blue/White
Left Front Speaker Positive Wire (+): Red/White
Got everything working nicely now.
Only wish I had a stock single-din instead of this double-din + metra thing...
