03 pedals for 01????
I thought i remember someone saying that the 03 pedals will fit the 01 tibby. Is this true and if so does anyone have any pics of them.
Thanks JD |
i dont know but it fits on an Accent
http://www.cobraspeed.net/ace/images/inter...ur/Dscf0005.jpg except for the gaz pedal, you need to small screw |
Yes they will fit, the clutch and brake fit perfectly.
As for the gas, you can use the screw method (kinda Ghetto if you ask me) or you can use silcone or urethane to put the gas pedal on. (take the OEM rubber off first though) Oh yeah, make sure once you put the silicone or urethane on, use some zip ties to temp. hold the pedal on. Leave it on for a few days so it sets. http://www.members.shaw.ca/kayjai/Pe...01st%20gen.jpg smile.gif [ November 27, 2002, 03:01 PM: Message edited by: KayJai ] |
i had try with contact glue and silicone but the pedal always falled... frown
Weve had atleast 4 guys use urethane and it's lasted since.
MAKE SURE YOU SECURE IT WITH TAPE OR BETTER YET ZIP TIES FOR A FEW DAYS TO LET IT SETTLE!! Or else you will make a mess of you floor when it falls off and you've got all that muck on your mats |
where can i get a set of those?
Peace |
Your local dealer can get them, if not let me know, I can get them.
smile.gif |
only 16$ CND for the kit, its a good price!!!
and its look better than any ractive pedals eek! |
Kayjai, how much should the dealership charge me? And i see you have to "glue" the gas pedal on, how does the brake pedal go on?
Peace |
Around $16 for the gas, brake and clutch, or just gas and brake if you have an auto.
You just slip the OEM rubber pads off and slip these ones on. The gas pedal kinda fits, but it's loosey goosey, hence the urethane. smile.gif [ November 28, 2002, 11:26 AM: Message edited by: KayJai ] |
