Winshield Spray
Old Aug 5, 2005 | 03:58 PM
01roller's Avatar
my windshield washer nozzles dont spray..... not clogged, checked all fuses in the interior and engine. any ideas??
Old Aug 5, 2005 | 04:11 PM
hold the lever in for like 10 seconds in your driveway. look for wiper fluid on the ground somewhere.
Old Aug 5, 2005 | 04:48 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
a bit of search...
this might help you Thread: Help: Window Washer Doesn't Work, removed dash and put it back
check:
1. water
2. motor (does it buzz when on)
3. lines
Old Aug 7, 2005 | 10:55 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Check the lines again. I had the same problem. Where the line went through the bracket holding the hood to the car (I dunno what to call them) it was pinched. I just pulled it out, ran it through a couple times and it was good.
Definitely check to see about the motor running too. If you hear no noise, you've got a motor problem.
