Will a clogged cat throw a check engine light?
Old Oct 5, 2011 | 02:49 PM
2XDreme's Avatar
Vehicle: 2001 Tiburon
Default Will a clogged cat throw a check engine light?
I think I have a clogged cat because my car has no power and when you hold your hand over the back of the muffler, and rev the car, you dont feel much exhaust coming out. But I dont have a check engine light. Would a clogged cat definitely throw one? How else can you tell if the cat is clogged other than the 2 things I mentioned?
Old Oct 5, 2011 | 08:54 PM
Compare to a car with a similar engine size, to see how much exhaust should be coming out. It would not definitely throw a code for a partial clog but it would not run strongly at high engine speeds.
http://tinyurl.com/3lcxqur
Old Oct 6, 2011 | 08:41 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
check out my thread i'm pretty sure mine is clogged and i thinks it's causing a bog and then surging and an occasional misfire.
Old Oct 7, 2011 | 04:34 PM
Sonique's Avatar
Vehicle: Hyundai Tiburon RD
Mine didn't
Old Oct 7, 2011 | 07:37 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
My 91 excel had a clogged cat and the acceleration was horribly slow, it did not throw a cel.
