Who wants side poly mounts for the RD?
I'm in contact with a guy that makes poly mounts for all kinds of vehicles. I'm going to give him measurements for making me a set of side mounts. I'd rather not have solid for these. Who else wants a set?
I thought Energy Suspension made poly mounts for Tibs, but could be wrong. Always good to have another option and possibly even cheaper too. :thumbup:
I would be interested depending on the price.
To be clear, I'm talking motor mounts. I don't know of anyone, not even Yaya, that makes the two side motormounts.
Did you get a ball park price?
Energy Suspension offers inserts for the GK but only for the front or back. |
Didn't ask. Didn't matter to me. Not that I'm a baller, but I want the part and it's not available anywhere else. Gotta pay to play.
I may be interested.
I'm interested in them for a 2001 Tiburon 5-speed.
I would recommend using a polyurethane mix that is not to firm. It should flex a little since the side mounts create the most vibration. My lower mounts are poly's and I filled the gaps in my side engine mount and tranny mount with a stiff polyurethane mix. That created horrible vibrations forcing me to swap them out for oem rubber mounts. I recently cleaned my old right side motor mount and re-injected it with a more flexible poly mix and replaced the worn out rubber mount. What a difference, way stiffer and the car actually vibrates less. Just need the tranny mount now. I still have the old rubber mount that is for the upper right side of the engine if you need to use it as a template. |
