Hyundai Aftermarket
-   Hyundai Tiburon Forum (https://www.hyundaiaftermarket.org/forum/hyundai-tiburon-forum-63/)
-   -   When you remove battery from 2K1 Tibby... (https://www.hyundaiaftermarket.org/forum/hyundai-tiburon-forum-63/when-you-remove-battery-2k1-tibby-2488/)
SilverTibby Dec 10, 2001 06:17 AM
I will finally get my KORE CAI next week or so after 3 months of wait. Anyway, I heard that if one removes a battery terminal cables in a wrong way, it can screw up an air bag sensor or another sensors. So I was wondering if this step is right steps to remove a battery from the Tib.
When removing a battery
1) Take out a negative terminal cable first
2) Then take out a positive terminal cable
When installing a battery
1) Put a positive terminal cable first.
1) Then put a negative terminal cable.
Does it sound OK to you guys?
[ December 10, 2001: Message edited by: Silver_Tibby ]
Iago Dec 10, 2001 06:26 AM
Sounds backwards to me.
I thought you disconnect the positive first, then the negative...just like when you're using jumper cables.
Julez Dec 10, 2001 08:26 AM
When I put in the SR gauges, I disconnected just the Positive and then when finished hooked it back up, no air bag light
SilverTibby Dec 10, 2001 09:02 AM
I see. Then I think I should remove positive terminal cable first. By the way, is positive terminal cable one that have red plastic cap on it?
Thanks all!
Iago Dec 10, 2001 10:35 PM
Yes.
Red = positive.
Black = negative.
The red plastic cap should also have a tell-tale + moulded into it. smile.gif
MajinCthonian Dec 10, 2001 11:04 PM
i removed the positive ONLY each time i removed the gauge cluster, and i removed the negative ONLY this past weekend when installing my power antenna. NO AIR BAG CEL. i think that it makes very little difference which side of the circuit is broken first if you are removing the battery, the only difference seems to be if you pull the gauge cluster WITHOUT first disconnecting the positive terminal.
Random Dec 11, 2001 12:37 AM
When removing a battery, always remove the positive first.
When installing a battery, always install the positive LAST.
If doing electrical work on the car, remove the POSITIVE cable.
SilverTibby Dec 11, 2001 04:03 PM
