What the hell!!??!!??
Vehicle: 2004 Tiburon Beta
Everytime I try to install an LED bulb, I blow a fuse. First it was my license plate bulb, I took it out and put an LED and it didnt work. I put back the old bulb and that wouldnt work either. Now it happened to my map/dome lights. I took one of the dome bulb out and put in an LED one. As soon as I did that the other bulb went out. Again I put back in the old bulb, and now whenever I open the door....the dome lights dont come on. Anyone have any ideas? help.gif
are you using resistors, and if so, how many ohms? you need to calculate the proper resistor voltage and sequence for the LED using Ohms Law.
http://led.linear1.org/led.wiz
<div class='quotetop'>QUOTE (purpletib @ Jul 27 2010, 03:51 PM) <{POST_SNAPBACK}></div><div class='quotemain'>You could always bump up to the next fuse size.</div>
that is by far one of the WORST recommendation you couldve made in this situation
fuses are there for a reason im sure he wouldnt like his car to light on fire
Didnt use any resistors. They were the right size bulbs, but they were those ones that have multiple banks of LEDs versus just the single LED like a regular bulb. Wonder if that had anything to do with it. I replaced the blown fuse and put the regular stock bulbs back in for now. No more fuses blew after that.
