trans help please
Old Oct 15, 2012 | 03:27 PM
cpennington89's Avatar
Vehicle: 2001 tiburon
Default trans help please
Cant get he rans to slide back in properly after new clutch install, any ideas? thanks
Old Oct 15, 2012 | 04:28 PM
make sure the fork on the top is in neutral position. I can't remember exactly what or where it is, but I think it's on top of the tranny.
Old Oct 15, 2012 | 04:42 PM
wheel_of_steel's Avatar
It's a kunt of a job, that's all. Make sure that the 'flywheel' and torque convertor are properly aligned. if you have already done that; get jiggling.
Old Oct 15, 2012 | 04:49 PM
pretty sure by clutch he means manual trans
how did you install the throw out bearing?
Old Oct 15, 2012 | 04:52 PM
Put it on the pressure plate, then bolted everything to the flywheel. Thanks for helping guys
Old Oct 15, 2012 | 05:05 PM
just as i thought
supposed to go on the shift fork first then once you got the trans on you snap it onto the pressure plate
you gotta get some snap ring pliers and try to take the bearing off....good luck
Old Oct 15, 2012 | 06:05 PM
OOOOO, ok thanks
Old Oct 15, 2012 | 06:37 PM
and DONT GREASE THE BEARING
DONT GREASE ANYTHING AT ALL IN THE CLUTCH AREA
Old Oct 16, 2012 | 04:14 PM
Alright guys thanks, I'm gonna work on it more tomarrow morning. It's my fiance and Is 4 year anniversary so I couldent get much done
Old Oct 16, 2012 | 04:18 PM
Regit's Avatar
Vehicle: 2000 tib
Ha ..The infamous "TOB" issue. as said above ,easy fix bro !!.. get her off, snap her in last
