Sunroof randomly started leaking
Old 07-28-2016, 04:56 PM
Tiburon2k's Avatar
Vehicle: 2K Tib
Default Sunroof randomly started leaking
My sunroof has randomly sprung a leak. It closes all the way but a little water is still coming in. Could it be the seals? I inspected them and they look ok with no holes in them. Could they still cause water to come through even if they appear to be in good condition?
Old 07-28-2016, 06:44 PM
sunroofs all leak eventually. The seals fail. Then the drains either show they are clogged or not. Try a skim coat of silicone lubricant around the seal. NOT silicone sealer, unless you just don't ever open the roof - in which case silicone sealer will solve your problem for a few years.
Old 07-30-2016, 05:10 AM
The gutters/drainage system is clogged with grease or debris.
