spark plugs for 1.8 coupe
are these ok to use for my car? it says its for 2.0 but i have the 1.8 still good to use?
https://www.ebay.com.au/itm/Set-of-4...AAAOSwEVZaXviK or these ones but slightly more expensive https://www.ebay.com.au/itm/IRIDIUM-...cAAOSwJ0xaYZFs |
I prefer NGK BKR5ES-11 from supercheap
or NGK Iridium Spark Plug BKR5EIX-11 https://www.ebay.com.au/itm/NGK-BKR5...4AAOSwq7JUE6dm |
Originally Posted by XGODZX
(Post 719205)
or NGK Iridium Spark Plug BKR5EIX-11 https://www.ebay.com...b4AAOSwq7JUE6dm ill give the super cheap ones a go thx m8 |
I used NGK's for the life of my Tib when I had it and they were great.
I would also use NGK, if you want something better then OEM go Iridium. I put over 100k on Iridiums with 0 issues, I only changed them when I got an oil leak to them from the valve cover seal.
Stick with NGK - don't fall for the gimmick stuff.
