Silly Little Orange Lights
Vehicle: 1998 Tiburon
Hey all, I recently ( 6 months ago) replaced my beaten and busted header and olde O2 sensors with fresh equipment. Before I had an evap code but didn't bother looking into it as my header was leaking badly. So as I mentioned I replaced the lot and now I've got 2 codes dancing on my dash;
P 0 135 - O2 heater circuit- Bank 1 sensor 1
P 0 131- O2 Circuit low voltage- Bank 1 sensor 1
Doing the install was relatively easy for me, no wire extension, 1st o2 into the header and second behind my cat. Any thoughts here? I'm trying to dig up a used but working sensor for diagnosis but I don't live in a tibby enriched environment.
Also I have a sort-of bog at above 3000rpm until about 4700rpm. Not sure if that is related. I notice that if I lay it to the mat it doesn't happen, when it does it really push off from 47000. I am running a 1.8 ECU I bought from a member here years ago.
check the connectors are wired right and that the guy at the parts store gave you the right stuff.
Also a thread title with something about cel's or the first o2 sensor might attract the eye of an expert. just a thought
Your first o2, is it in a runner or farther down in the collector? If its not in the runner then get a o2 bung welded in the runner closer to the engine so the sensor gets the proper readings. The stock position is in the manifold.
